Can't select faces to shell
Hi - I must be missing something obvious here, but perhaps someone can point me in the right direction.
I create a sketch profile for a lampshade and rotate around a vertical axis. Next, I want to shell it, but although I can select faces to remove (basically the flat top and bottom) prior to the shell command, when the dialogue box appears, I can no longer select those faces. What's up? How can I shell this rotation?
cyclonewade OS Professional, Mentor, Developers Posts: 53 ✭✭✭
@biscuitlad
The picture looks your revolve is a surface, which explains why the shell feature is not working for you. I would recommend closing the profile(if not already) and make sure the revolve generates a "solid" part. Once this happens, feel free to use the shell command.
W
imagine.create.deliver2
W
This makes it particularly important to at least name the person you are replying to, or (better still, because one person may have posted many times) quote the part of their message that you are replying to
