Flexibility of Patterned Sub Assemblies
 BMcGaffey
                    Member Posts: 29 ✭✭
BMcGaffey
                    Member Posts: 29 ✭✭
                    Hi There,
I was informed by Onshape support that the flexibility of sub-assemblies is removed once they are patterned. I am looking for an alternative.
Ideally, if I move one of these camera brackets, the other three will follow. I have tried linking the sub-assembly slider mates with a linear relation in the top-level assembly, but that doesn't seem to work.
Any ideas on how to achieve this? I would definitely like to keep the sub assembly. I know if I built it all within the top-level assembly and patterned it, the motion would be possible, but this would create a pretty messy BOM.
https://forum.onshape.com/discussion/10425/patterned-sub-assemblies-to-be-flexible-when-patterned-not-act-as-rigid-bodies/p1
I am probably missing something, if I assemble 2 instances of the sub assembly into the top level assembly, then try to add a linear relation between the slider mates in the sub assemblies, it breaks.
Should I be going about this differently?
Cheers,
