Variable chamfer
kristoffer_falk
                    Member Posts: 23 ✭✭
                    I would like to make a chamfer with variable settings for the chamfer.
It is along the highlighted edge - here I would like a chamfer with distance 1 9 mm and distance 2 2 mm. For the non-highlighted part of the same edge I would like to have distance 1 and 2 to be 2 mm.
Is that possible? Every attempt I make ends up with "failed to generate", and I am not very good at troubleshooting, when that happens...
It is Chamfer 1 in the current design. The chamfer settings for the marked part are actually fine, but on the unmarked part I need it to be steeper (like 2 mm for both distances.
https://cad.onshape.com/documents/b9ee34a40f17306b104a1a1a/w/3b6082cb694d09de8bc4f90c/e/c258b6e57aa15b1c3444b16f
yeap:
Now I got it right.
1) Add a variable radius fillet
2) Delete the faces generated by the fillet
3) Loft between the start and end of the (now missing) fillet (no start or end conditions)
4) Smile
