Sweep around a path that is intersecting
muchete
Member Posts: 5 ✭
Hey there!
I'm new to Onshape so please excuse the stupid question, but I only want to sweep the triangle around the path that I imported.
But apparently that doesn't work because the lines touch. Is there any way to solve this?
Greetings Michael
Greetings Michael
Can you post a link to your Document? This makes it easier for us to take a look at your example. Thanks!
Sure: https://cad.onshape.com/documents/43783eb9617446f4553741fb/w/f098e9d5aabe3abd2aa981cb/e/395b55ff65488ada90113356
@owen_sparks
i tried this, but somehow it always shows errors when doing the sweep. It seems to be an issue of the surface thats within
https://cad.onshape.com/documents/e540f10f3118deac9bf81d59/w/ea376967b0711076de37fe97/e/be1109963c289667a65a1f48
But I don't quite get it. Should I have changed the radius of the L arch slightly?
Anyway, solved my issue. Thank you.
The curve in the LOOK HERE sketch is too tight (small) for the sweep to work. This is part of the reason why you get the message that it intersects on itself when you try to do a sweep.
So, I made a new sketch (Sketch 1) which is NOT as tight
I also reduced the width of the base of the triangle that I used in the sweeps from .299 to .28
Doing both of the above allowed me to make what you see in the document that I have a link to, in my above post
Watch the below animation
If you’re going to have the problem of a self intersecting sweep, It’s likely it’s the inside of the curve along the sweep that intersects with itself. Because the inside of the curve is making a smaller or tighter turn then your path, and that’s usually where you start getting these self intersecting problems.
In the below animation, I have it set to do a SURFACE sweep. Now in this animation, I am using your path, which is the LOOK HERE sketch. And I’m also using your triangle as the shape to sweep.
The two above fail because they’re trying to make a tighter radius then your path has. And as is, your path has too tight of a curve to allow these two segments to make a sweep
So, my solution was to make a looser curve, and make the base narrower. And doing these two allowed what you see in my above document
