Chat Box Inside Documents
Member Posts: 36 ✭✭
A chat box on the side you can pull up with a button or arrow so that you can talk to other people in the document.
Would help when working on team projects and when working with support
  • Member, Developers Posts: 452 EDU
    Yes; this would be very useful! I often have to open Discord or Slack when I'm doing a design review or helping someone model something, and having to constantly switch programs really breaks the flow of productivity. It's the same in Google Docs--it's awesome to hop on and start working together remotely with no fuss or external tools required. BTW, @Mazie_Houchens
    , you can vote for your own improvement request.
  • Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    @Mazie_Houchens
    @alnis_smidchens
    This can already be done with the comments in a document (they work in real time)
  • Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
    @Mazie_Houchens this is done in comments today
  • Member, Developers Posts: 3,944 PRO
    They can also double click your picture in the top right and follow your mouse move movements
  • Member Posts: 648 ✭✭✭✭
    @lougallo, @MBartlett21 - Its good to now that comments can be used this way. However, to me comments =/= chat, and therefore would provide additional value in some cases. Just like email, while near real time is not the same as chat.
    Comments - while they may update in real time, are for asynchronous and persistent (not necessarily permanent) communication and documenting a chain of thoughts about something. Better for documenting and responding to focused questions, solutions, tasks, and feedback.
    Chat - synchronous, real-time, non-persistent communication that isn't kept with the document. Better for longer, less focused, back-and-forth discussions that you don't want/need archived.
    All that said, I think a "chat" would provide value, but I wouldn't prioritize it very high, personally.
    edited December 2019
    You can always create a featurestudio and chat in real time there too
    I've done that before
    Good part about that is you can open the featurestudio in a new tab/window and have it on your second monitor or whatever so you can still multi-task
    @john_mcclary
    Including making many red underlines in real time too :D
  • Member, Developers Posts: 2,660 PRO
  • Member Posts: 39 ✭✭
    @lougallo
    How can the person know that I want to come in contact ?  There is no message from anything that indicates that there are comments.
    Only if you accidently opens the Comment panel you can see it.
