FILL: Merge With All vs. Merge Scope
ArgoArgo Member Posts: 4
As this is my first community question, would like to start by saying: THANK YOU Onshape! I use CAD for hobbying/make and have come across from Sketchup (please don't judge me! :wink:)
Also, Happy New Year!! :smile:
I have been learning by creating a tubular mitre/web. For far too long I could not figure out why I was unable to convert the resultant surfaces (from extrusions, bridging curve, etc) into a solid. By 'clicking all the buttons' I have got the job done. However, this now begs the question: what is the difference between Fill: Merge With All, &, Fill: Merge Scope? Sorry if this is obvious, but can anyone explain why one operation works and the other doesn't? Here are screenshots ("Surface3" is all the manifold geometry you can see) :
Fails with error: "Cannot add surface with existing geometry"
Works:
  • ArgoArgo Member Posts: 4
    That's the answer, thanks Neil :) Hidden surfaces it makes no sense to merge with - exactly!
    Because Fill (Add) defaults to 'Merge With All', I (foolishly) assumed OS would wave its magic wand and ignore non-logical entities in the Merge  :s
    Er, going to show my newbieness and ask why not Surfaces? My goal was to change the surface  into a solid, which OS did perfectly. I suppose I could have used Enclose? Or am I overlooking a fundamental?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,997 image
    You could probably sweep the triangle as a solid and add the corner piece on after. Maybe 6 features in total?
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited January 2020
    @Argo
    The GIF below shows the solid modeling method that Neil is talking about.
    Great presentation @steve_shubin :+1:
    Owen.
    @owen_sparks
    Thanks Owen
    I’ve got a video editor for my iPhone called LumaFusion. It’s fast & easy to use. It’s my second favorite app - right behind Onshape
    Many thanks to both of you, I get it now  :)
    I agree with you Owen, Steve's GIF was very useful.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,065 PRO
    edited January 2020
    @john_mcclary
    Thanks John
