Have something weird when I mirrored part.
I made the half sketch, so the headlight bucket would fit inside, then mirrored, then pasted it into the main sketch. It will extrude the "center" bolt holes but it won't extrude the actual center. I can't select the center or all the lines. What did I do wrong?
Thanks...
Bob
You can tell by the color:
The inside is white so you will need to find the gap. It will be located by one of the end points where two lines meet.
The easiest method is to draw a line and try to section off the sketch is small bits, then see where your broken line is.
@bruce_williams created a nice animation of this process here:
https://forum.onshape.com/discussion/12829/why-is-this-letter-not-extruding
Your gaps are here in the blue circles here:
You should go back and clean up that area properly.
Also, try and keep the detail to a minimum when sketching. these sketches are pretty "busy" which makes them hard to read and debug.
Also try and take advantage of patterns when possible,
explicitly defining every feature like you would detail on paper, or 2D CAD is not recommended in parametric CAD.
It should be more like this
Hole sketch
Only 2 dimensions needed, everything else is a pattern or a constraint that is driven from existing geometry
Have a look here:
https://cad.onshape.com/documents/6d61a4ca559e0b6063990e02/w/cdad29c712643412935e8010/e/11e77bb5850380a2946b2625
I was merely pointing out some undesirable practices that can be increasingly difficult to manage.
It is not necessary if you only have one part to worry about, and you will never update it. But when you need to make down the road changes, or work with a group of people. It can be a disaster.
I work with people who have been modeling for many years and they still sketch like that. Which means nobody slapped their hands early on. Now they are dependent on bad habits and they make their job harder on themselves because of it. It is hard to not say anything sometimes, please don't be offended.
