modifying a feature on an imported part.
joseph_conlinjoseph_conlin Member Posts: 10 PRO
I am trying to modify a slot on an imported part. Tried using move faces and the offset but does not do what I want it to. The slot is currently at .375 X .500 and I need to change it to .45 X .500.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Try Move Face / Translate and pick one of the straight lines of the slot to define the direction.
    The "select faces" tool with the "pocket" option selected may help.
    edited January 2020
    You can re-cut the bigger slot with a new sketch & remove extrude.
    You can delete the existing faces and start over using a new sketch & remove extrude.
    My favorite is to build a new part based on the imported one. First; you'll want to re-orient & re-position incase the author didn't do that correctly.
    You can do almost anything to a dumb solid and make changes to it. There are really no downsides to a dumb solid. It's better than a model that's poorly constructed.
