Release Management Questions
robert_morris
OS Professional, Developers Posts: 173 PRO
I've been looking through the help file on the new Release Management stuff and have a couple of questions.
- In the help file for releasing assemblies it states: "Released parts linked from other documents, in the Assembly, are reflected in the Create Release candidate dialog and no new revisions of the parts are created when the Assembly is released". What about parts that are within the same document? If I create a new revision for an assembly that contains a part which has not changed from the same document, will the revision of that part be bumped up as well?
- If a release candidate has been rejected, will the revision value (A, B, C..) get reused the next time a release candidate is created, or will it be bumped up to the next value.
1. If you have a part that is referencing the workspace part and not the released part, the revision will be bumped when releasing the assembly. If you are releasing a part that is referencing the released part, then the revision will not be bumped.
2.The revision value only gets bumped when a release candidate is approved. Rejected release candidates appear as open triangles in the Versions and history graph.
Probably your next question:
If there are two pending release candidates that contain the same part with the same pending revision value, the first approved one wins and takes the new revision value. We will not automatically discard release candidates for you, nor will we make you take action on the pending one. Your pending release will show you that your part's pending revision value has already been taken and the only action is to either discard or reject.
Thank you for the clarification.
Having the part revision automatically bumped when I bump an assembly revision is a big giant no-no for me. For example, adding a new part to an assembly and creating a new revision shouldn't bump the revision of the other parts since they haven't actually changed.
So it seems my two options to prevent this are:
- Move all the parts into a separate document, release those, go back to the assembly document, update the links, and then release the assemblies from that document.
- Keep the parts in the same document, release those. Then completely rebuild my assemblies and subassemblies to use the released parts (there doesn't seem to be a way to switch from a normal part to a released part like you can with versions), and release the assemblies after all that has been done.
Both options currently require a bunch of extra time taken, and the first option seems (to me at least) to lose a big benefit of having things all in one document. It would be nice if you could switch an unreleased part in an assembly to a released part. That would reduce the extra time taken for option 2.I could also be missing something and there's an easier or more correct way of doing this.
You got it mostly. Note that revisions are versions, and if you are currently referencing a version, you cannot change to the actual revision (yet). You would just be updating to the version that was created at the time of the approved release candidate. So you would still get version updates. Broken down:
- If you are referencing a version, you can change to another version or workspace.
- If you are referencing a revision, you can change to another revision, a version, or a workspace. But today, if you hop off the revision train, you cannot get back on without reinserting the object.
Right now Release management works best if:
1. Don’t mind bumping revisions often. They are free and even if there were metadata changes, the part has changed. If the part has changed, you probably want to re-release the assembly when all the other parts have been changed as well.
Implementing revisions and the release process going forward is recommended.
2. You have the patience to go through your assemblies that matter, release the parts and reinsert the parts. This is a very large ask and I don’t suggest this if you enjoy your weekends.
3. Start using them on your next project.
4. You are brand new to Onshape and you only know Onshape as it is today.
In previous PDM systems, bumping revisions was a no-no because the process was laborous and required the design to stop just for everyone to get on the same page. This is just the beginning in Onshape’s mission to make this once tedious task something that just blends in, feels natural, and does not get in the way of what engineers like us love doing: Engineering and solving problems together.
We know that the ‘change to revision’ work is work that needs to be done. As with the rest of Onshape, expect workflow improvements in the future.
Thanks again for the info. I have no doubt there will be improvements in the future, and we all appreciate that.
I don't say that automatically bumping revisions are a no-no for the reasons that you point out, although those can be true as well. I say they are a no-no because if a part revision is bumped up, then that is normally a signal to whoever is manufacturing the part that something is changed. If there is nothing actually changed in the part, then that wastes the manufacturers time (and ours) as they try to figure out what's different and why it isn't called out.
We are working on improving versions, revision, linked documents and the general updating and notifications of it all. Our system is a very different paradigm from file based parts with PDM tracking on the file itself. From what I am gathering from this thread, there is difficulty in that there is no one-to-one (or one-to-many) link between actively being worked on parts/assemblies and their released equivalent leading to a grey area of whether to insert & reference the workspace or released part/assembly?
Can you clarify what you mean by "as the state of release does not carry as it does in conventional CAD systems."? From my initial reading, I would disagree but I don't want to form an opinion based on a misunderstanding.
What I mean by the state not carrying is that as soon as a part has been marked as released in a version the current work space, main, shows that part in work again. The confusion comes when there has been multiple different release packages releasing different parts. It is difficult to determine what has been released previously, what still needs to be released, and if there have been any changes to a previously released part. You could very easily release the same part twice as two different revisions without making any physical changes to that specific part because the overall document had undergone some changes.
For example, I release an entire assembly of parts and it is approved and that version is marked as released. If someone else opens up the document and begins working in the main work space they would not know that assembly had been released without digging in and looking for it. Our issue is that it is hard to get a high level view of the current status of all parts, assemblies, and drawings.
Hopefully that makes some sense, but I'm happy to talk through it more if it would help.
Also, can we have a mix of letters and numbers, I have seen some companies use numbers for pre-release revision/versions and letters for post initial release revisions.
Thanks to all for working through this-- this thread has been super helpful for me as I try to implement release management. Wanted to throw in another question that this led me straight into:
If we've already committed to spending our weekends updating our assemblies with released parts, then in order to evaluate the impact of a part-level change on a released part in an assembly, it seems like my options are:
- make the changes to the part in part studio, release a new revision of the part, and update to the most recent revision in the assembly
- make the changes to the part in part studio, change the pointer in the assembly from the revision to a version, then update to the current (modified) version. Then, if change is OK, release part and re-insert released part into assembly (probably requiring some level of assembly rebuild)
- make changes to the part in part studio, change the pointer in the assembly from the revision to a version, then update to the current (modified) version. Then, if change is OK, release part and change the pointer back to the new revision.
Option 1 would require a massive number of revisions, even for investigations, which seems like an abuse of the tool.Option 2 would require assembly rebuild for any part change.
Option 3 seems great, but requires the 'change to revision' work that you reference above.
Do I have my head on straight re: my options here? If so, is option 1 or option 2 the current recommendation? And any insight into where in the pipeline option 3 is?
Going back over your list:
Option 1 is a lot of work, agreed. This will be much easier when we eventually have the ability to push/propagate revision updates to assemblies in some way.
Option 2 is pretty laborious. Personally, I wouldn't do this.
Option 3 you are totally correct this would be great.
We implemented release management with the intention to cater to as many workflows as possible, with an increasing amount of workflows being supported every few weeks. I believe what is 'recommended' all depends on your release process internally. Your team probably already has an idea on how YOUR project should develop, and your CAD/PDM should be causing as little disruption to that process as possible.
If your team has a very locked down mentality, start (and keep) everything at revisions so there are approvals for everything.
If you don't mind extra revisions, you can keep your assemblies as is and rereleasing the parts or assembly however you see fit.
There is no one size fits all solution to product development. We know the change to revision workflow is very desirable functionality and we are working on it.
Any thoughts on work flows to manage the release states?
The conversations above have been helpful.
We are getting started with rev management and I am wondering if you can share your best practices / experience for OnShape document control. (In addition I see the issue of control models (rA) vs. drawings (rD) and do you keep them at the same letter?)
I recognize that a lot of this is dependent on the specific organization.
Thanks in advance for any insights.
I'm definitely looking forward to more streamlining from the Onshape dev team here.
- create/edit parts + assemblies until happy.
- release parts and drawings together at same rev level.
- update assembly to include only released parts.
- release assembly and assembly drawing at same rev level.
This could be a little confusing to work on the assembly and make sure you've got the right part version in your assembly in your workspace. But after releasing the parts, you can update the assembly and review that everything is still correct before releasing it.@Evan_Reese - in your example - do you actually release two different assemblies? Or does one assembly just allow you to release the parts and not the top-level assembly?
