Duplicating or Splitting a Part
bart_harris
Member Posts: 29 ✭
I need two hinge bars. I have drawn one. How should I make the second? Do I have to make it in a new part studio or can I duplicate it or split it in the same part studio? Here is an example:
https://cad.onshape.com/documents/6851b01973b14124bcd6224a/w/44ab6ee4efae4df08c015b92/e/853e76049eec44a1a4d5e725
Many thanks,
Bart
Many thanks,
Bart
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@bart_harris You can use Transform with the copy function.
Here is the final. Make a in place copy with transform, then use a single sketch to do the cuts and assemble..
(link to workspace)Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
(link to workspace)
Whereas the other works to duplicate whole parts, or faces on parts.
("Faces" is a checkbox option within part-level "linear pattern")
