Multiple surfaces from single feature
Sindre_Abrahamsen
Member Posts: 5 ✭
I want to draw a profile sketch and then extrude/revolve/sweep the whole sketch with a single surface feature. It is okay that the command results in several surfaces, but I want to avoid the extra features in the tree and the extra mouse work.
Example profile sketch:
The surface extrusion fails if I select both the circle and the line, so I have to do several features. Is it possible to make this work?
