Versioning - it certainly seems like I'm missing something
I started a few parts before I truly understood part studios and the power of creating sub-assemblies with one model tree. So, I jumped right in and created parts in separate files and brought them together in a separate assembly file. I have a few questions I'm hoping to get some help with. Here goes:
1. Every modification I make (to a part in a part studio, in a separate document) requires a new version before I can see the changes in the assembly. This is very time consuming. How can I see edits on the fly without needing a new version?
2. When I do edit in-context, I can't see other parts, they're almost completely transparent. Is there a way to control appearance while editing parts?
Thanks!
Thanks!
And then Replace Instance functionality to change assembly references from linked versions to the workspace
Lana's method above will get you into a single document. Then everything will live update.
Multi-document structures are more geared toward common parts you want to re-use in many projects, with minimal updating.
Like a foot, or sensor braket... then keep your unique project stuff in a single document.
To understand more about what Documents are and how to organize them check out:
- Navigating Onshape
- Product Structure Organization Tips
- Best Practices for Managing Data in an Onshape Document
To learn more about Versions and the differences of Revision-management check out:- Document History and Versions
- Linked Documents
- Understanding and Working with a Document's Historical Data
To learn how In-Context modeling works in Onshape see:- Managed In-Context Design
Hope this helps!
