How to change the size of circle diameter
In tutorial  video 2 there is a menu item to change the dimension.
in new version there is no such an option.
How to change the sizes of the fugures?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,413
    Is the sketch active? If the sketch geometry is grey (inactive) then double-click the sketch from the feature list (not from the screen) or right-click the sketch on the screen and click edit.
    rustam_mizovrustam_mizov Member Posts: 7
    where to click to change the diameter. this is a mobile app
    That makes a big difference...   with the sketch selected (like you have in the image) tap on the screen with 2 fingers and select edit.
    It does not solve issie since I could NOT find the "Dimension " menu item. If you coukd at the screen attached in the previous version it was a specual menu item. Now it has gone.
    You have the latest version of the app? Can you post a screenshot of what you are (not) seeing?
    It does not solve issie since I could NOT find the "Dimension " menu item. this video is what I am seeing.
    https://cloud.mail.ru/public/7r4w/mjANAH1bQ
    That menu of icons is scrollable - the dimension icon is below the slot icon
    jack_hooverjack_hoover Member Posts: 2
    Could not find a way to give any values for circle.  I followed those instructions but apparently I dont have "edit" option.
    neil_brennanneil_brennan Member Posts: 5
    Basic editing in Onshape is incredibly frustrating and seems to work in different erratic ways depending entirely on developer whim. I tried setting a dimension on my circle (as suggested above) only to get an error message saying you can't set a dimension on the point in a circle. Then I had to "escape" the dimension to do anything else. I tried double-clicking in as many different parts of the circle as possible, none of which worked. Then I tried single-clicks and occasionally something useful looked like it flashed on screen. I can only imagine the number of miserable people who just try this and give up.
