How to change the size of circle diameter
rustam_mizov
Member Posts: 7 ✭
In tutorial video 2 there is a menu item to change the dimension.
in new version there is no such an option.
How to change the sizes of the fugures?
It does not solve issie since I could NOT find the "Dimension " menu item. If you coukd at the screen attached in the previous version it was a specual menu item. Now it has gone.
It does not solve issie since I could NOT find the "Dimension " menu item. this video is what I am seeing.
https://cloud.mail.ru/public/7r4w/mjANAH1bQ
https://learn.onshape.com/courses/onshape-on-an-ios-mobile-device
you need to define a dimension for it in the sketch - then you'll be able to click on it and edit the value. if you select a circle with no dia dimension defined, it'll show you the original dia you dragged it out to when you created the new circle and you'll see if in the bottom right callout, but you won't be able to change it.
I think you can select dimensions, then click on the object. You'll get an arrow thing and choose which dimension you want to change. Then you can enter a number for it.
