Merge available?
I'm trying to branch and merge simple shapes. I don't even see a Merge button in my Versions view. From the documentation, it should be right there next to the Save Version button, but I don't see it. Has this feature been removed? Thanks!
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
@adam_76 @jakeramsley answer is correct. You will NOT see a merge option on the same workspace you are on. If you select a workspace to pull changes into your current workspace you will see the option. This is one thing that can be confusing to new users of Merge. MERGE = PULL
With that being said, you are selecting a workspace or version from the graph to pull changes into your current space. Just remember, everything in every tab merges. We will work on making this selective and have more tools to assist on making decisions on merge in the future. Hope that clears things up for you.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
We will update the documentation around this.
