Merge available?
adam_76adam_76 Member Posts: 3
I'm trying to branch and merge simple shapes. I don't even see a Merge button in my Versions view. From the documentation, it should be right there next to the Save Version button, but I don't see it. Has this feature been removed? Thanks!
    Merge is located under the gear menu of a version/workspace that isn't part of the same tree.
    We will update the documentation around this.
    Jake Ramsley
  • adam_76adam_76 Member Posts: 3
    This just doesn't appear for me. Please see attached image.
    Got it. Sorry for my confusion! Thanks for your help.
    @adam_76 quite alright. That is why we are here!
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 75 PRO
    I made a mistake and pulled the main into branch . reverse in history doesn't make any difference I am lost?
    There should be a history entry on the branch that had main pulled into it that says something like 'Merge from Main'.  If you select the entry just before it and chose 'Restore', the merge effectively isn't applied.  If there is an issue with this, please use the '?' option in your document and open a ticket with support.
    1.png 295.9K
    2.png 263K
    Jake Ramsley
