Improvements to Onshape - March 9th, 2020
Exactly 3 weeks has passed since our last update and we are back again with another. This update includes improvements to the newly released Exploded View tool, drawings, and more. Let's dive in.
CAD IMPROVEMENTS
EXPLODED VIEW IMPROVEMENTS
You can now view exploded views when using Follow Mode in Onshape. This can be a useful way to dissect assemblies while collaborating with others.TABLE IMPROVEMENTS
Improvements have been made to the grip points in tables that allow you to resize all columns or rows at once.CALLOUT IMPROVEMENTS
Improvements have been made to callouts and Datum symbols that have eliminated the grip point for dragging. Now you can left-click drag any piece of the annotation and it will allow you to drag.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
8
Good work
I like the slight adjustment to all the tool icons etc. Crisper, and much more legible.
Also: when I search for a Custom FeatureScript (Alt+C): the full list no longer flies out over my search results! Yay!
[EDIT: nope, this behaviour actually hasn't changed...must've gotten lucky).
I agree - feels snappier all around right now.
Thanks for making the annotation grips easier to grab, and table quicker to size
(still would be nice to get a table format, with pre-sized cells and properties not mirroring the assembly bom)
I like the improvements to the tables but what would be really is good to be able to hide a column or be able to set the drawing format for the table in the assembly which is separated from the assembly table setup.
However, when I opened Onshape this morning, half of my features were missing from each toolbar and I had to manually add them back. Was this meant to happen?
Also, the forum font seems to have suddenly become a lot smaller
It appears that behavior only happens if your mouse is over some part of the toolbar during the search. So if you are using the shortcut to open the search, and leave your mouse over the graphics area, those tools will not overlap your search.
You can also get rid of it by unchecking "highlight in toolbar" in the bottom right corner of the search itself, but this is only persistent over the current session and will not survive a refresh.
Thanks for the "highlight.." tip.
www.myzhar.com
The position number snaps to a wrong position when the mouse button is released.
Could you please fix that? Thanks :-)
