Is any option to add tolerances (or notes) to the sketch dimension?
MS_021MS_021 Member Posts: 7 PRO
  • MS_021MS_021 Member Posts: 7 PRO
    A dimension is not absolute and required to have tolerances.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,005 PRO
    You can add tolerances in drawings only.
    The only way to add tolerance in a part studio sketch will be to add a comment in the dimension
    such as:
    2.0 in /* +/- .005 */
    anything in between these two marks: /* */ will be ignored by the sketch solver.
    Unfortunately they will not be parametric to a drawing...
    And there is no way of seeing the comment until you attempt to edit the dimension (see above image)
    This is what it looks like in drawings:
    John,
    Unfortunately this “NOTE” /*tolerances*/ will be visible only if you double-click on dimension and disappears when dimension is not active.
    This time is wasted.
    Thank you.
    I did mention that in my original post.  Sorry those are your options.
    There are some improvement requests for this somewhere. You should add your vote
