Rotating a sketch on plane
Hello,
I have managed to draw a sketch at an incorrect angle on plane. Is there a method to rotate the sketch?
Regards,
Sunil
Regards,
Sunil
With complex sketches it will be quite hard to find the right combination of constraints to do a drag rotate while maintaining the sketches intent.
The other alternative maybe to rotate the features created with the sketch after creation.
After we have possibility to import dxf/dwg into sketch, I would like to see rotate/move/copy selected entities in Onshape too.
