Turning assembly sketches on in drawings
in Drawings
I have some layout sketches which have been added to an assembly. Is there a way to turn these on to show them on the drawing?
MBartlett21 Member, OS Professional, Developers Posts: 2,061 ✭✭✭✭✭
There does not seem to be a way to do this.
You can create a sketch in a Part Studio and insert a view of the sketch, then align it to the assembly view you want.1 -
BMcGaffey Member Posts: 29 ✭✭
Bumping this as we desperately need this as well. We do a lot of lighting/optics work, so assembly sketches in drawings for approval are a must have. We lose all the accuracy placing the sketches by hand. Hope to see it soon in a new release8
I'd rather have sketches with multi-color assignment. I'm on your side.
The alternative is to create Part Studio "fake" geometry to convey what is really sketch quality (lower overhead) entities.
https://forum.onshape.com/discussion/9366/ability-to-show-sketches-in-assemblies-on-a-drawing/p1
- In Part Studio: Create a Composite Curve with your desired sketch elements (construction geometry doesn't work, and you can only have a elements that connect at their ends, can't have multiple curves or intersecting curves). For complex sketches - might need a couple Curve features.
- In Part Studio: Create a Composite part: select the Curves you need in the "sketch". You can also select surfaces or bodies...in the example blow, the text ("this is text....part") is also in the Composite part.
- In Assembly: Insert Composite part
- In Drawing: Show view of assembly - the curves in the Composite part show up in the assembly
This is clearly not what you guys are after, but for simple outline, skeleton, or bounding box type assembly sketches, this might be a temporary solution.Couple of interesting things about this:
Most of the time just need a couple of entities to dimension to. This may be enough for the time being
Sure beats modifing the final product to have a tiny notch cutout just for a dim...
