Can I relate a dimension to another?
Example:
the vertical side of a rectangle must be the half of the horizontal so that when I change the horizontal dimension the vertical one will change automatically
Thanks for your support
john_mcclary Member, Developers Posts: 3,959 PRO
For simple divisions like half. you can just use geometry instead of a variable.
here you see i created a construction line, made it equal the short edge, then constrained the end point to the mid point of the long edge.
1
I will use your suggestion for this simple action.
In my case I prefer to use variables, I probably made the wrong example to simplify my question.
Thank a lot for the support.
