Inch to mm
ehsan_pazookiehsan_pazooki Member Posts: 52
Hi guys, I changed the size settings of my Onshape to millimeter. But I still see tha value of dimensions in Inch. Each time if I want to define a surface or something, I must write not onlye 5 or 23 (as an example) but "5 mm" and "23 mm". If I do not write "mm", it will be defined in Inch. Is there any way to fix this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Setting units defaults is only for new documents. To change the units of the current doc, look in the "hamburger" menu next to the Onshape logo top left.
  • ehsan_pazookiehsan_pazooki Member Posts: 52
    @NeilCooke
    Thanks man
    Thank you so much
    You helped me
