Inch to mm
Hi guys, I changed the size settings of my Onshape to millimeter. But I still see tha value of dimensions in Inch. Each time if I want to define a surface or something, I must write not onlye 5 or 23 (as an example) but "5 mm" and "23 mm". If I do not write "mm", it will be defined in Inch. Is there any way to fix this?
NeilCooke Moderator, Onshape Employees Posts: 5,891
Setting units defaults is only for new documents. To change the units of the current doc, look in the "hamburger" menu next to the Onshape logo top left.Senior Director, Technical Services, EMEA1 -
john_mcclary Member, Developers Posts: 3,959 PRO
You will need to set your document units to mm.
The Onshape account setting (i believe is what you changed) is the default for new documents5
Thanks man
Thank you so much
You helped me
