Assembly: Why do Suppressed Parts Error Associated Mates?
Member Posts: 195 PRO
edited August 2018 in General
When Parts are suppressed in an assembly the mates corresponding to the parts shouldn't error out in my opinion; they're still valid when the Parts aren't suppressed right? They should be valid with simply some visual indicator that they're those mates are valid, but the Part(s) are suppressed.
¯\_(ツ)_/¯
  • Member, OS Professional, Mentor, User Group Leader Posts: 2,142 PRO
    Are you thinking there should be a differentiation for errors that are created by suppression which will help solving mate problems?
    How do you feel about related mates being deleted when a part is deleted? I find some time I first suppress a part to make the mates fail, relink mates to a new part, then delete the original part.
  • Member Posts: 195 PRO
    @brucebartlett I may have parts suppressed temporarily during the design and they may still very well be valid later and I don't want errors showing up in the List as it may interfere later interrogating other "real" errors of newly added mates etc... I would think this will also correspond to working with Assembly Configurations when they arrive.
    If parts are deleted then I think the corresponding mates should be deleted as well. The redefinition prior to deleting to other components is a nice workaround. Either way, if we had a visual for which mates are simply suppressed should still work in your case.
    edited August 2018
    Ahh, ok. It's a bit of work but in this case, I would name the mates and suppress them along with the part.  Now we have the ability to reorder mates, so I would group them together as well.  Hopefully, folders for mates will come soon too.
  • Member Posts: 24 PRO
    edited September 2018
    agree with @john_mcclary
    red angry mates tell me there is a problem that needs to be fixed.  In these cases, its not a problem.  Its just that the parts are suppressed.
    I was hoping someone from Onshape chime in on changing this behavior...
  • Member, Moderator, Onshape Employees, Developers, csevp Posts: 663
    Hi Don_Van_Zile,
    This is something we can look into, but will likely be prioritized behind other work that we are doing in Assemblies.  Essentially, the current behavior isn't great but it is technically right as the individual mates now fail to solve when including a suppressed instance.
    Jake Ramsley
    @jakeramsley Thanks for the honest response; I still don't like the exiting behavior. I would think this work would be part of the "Configured Assemblies" spec since components will invariably required the need to be suppressed and suppressed without error; unless you guess have something else planned  of course!
    Another "error" behavior that unnerving is with the system solving for things that haven't happened yet; and take it too far. When adding mates and selecting the newer green check applying it from the toolbar popup the next mate is already overdefined. This makes me think for a second that the previous mate overdefined the assembly almost every time only to quickly glance again and be reassured it's just trying to auto-solve.... for NOTHING even selected...for the next potential mate. this needs to be changed too in my opinion with the next mate waiting for input not being shown as an error:/
    Worse yet, it even starts in an error mode to the user which I can get past. But this isn't intuitive.
  • Member, Developers Posts: 3,942 PRO
    It is just reminding you there are no inputs, sometimes you may hit shift+enter a couple times and you will have an extra fastened mate with no input, so you can spot it easy. (happens to me pretty often actually :)
    I think red would be ok in this case. (OR yellow)
  • Member, Developers Posts: 2,660 PRO
    I'm content enough with he above by choosing to interpret red as "not happy yet" rather than as a hard error state, but agree orange would be nicer.
    I totally agree with Don_Van_Zile's original post. Supress a part = suppress its mate. Is there an improvement request on this issue? I also have some other toughts about mates:
    I find it unnecessary difficult to locate a part or assemblies corresponding mate. It would be nice to be able to right click a part/assembly and press "edit mate" (if any mate has been created). If there are several mates defining this part/asm I think those should belong together so you can edit all at once when you click "edit mate(s)". Today you can press "show mate". After that you need to locate it/them either in the graphics window or the model tree, right click again and find the edit option. Changing a parts position can take some time and I think that's a flaw because you do it all the time when you work in assemblies. Mates should rather be organized as a sub member of the part/assembly and not in a separate - and quickly very long - list which gives no overview as it is today. It should not be necessary to rename the mates to keep track of them. Renaming takes time.
    Mating an assembly: Onshape encourages you to choose one part of the assembly and use this to define the mate. If you some time later want to change the assemblies position you have to be a detective to sort out which part was used for this mate. It would have been better if the mate was associated with the assembly itself even tough you use one parts geometry to place it, so that you later can right click the assembly name in the model tree and press "edit mate" directly. Save the detective search work.
    Avoid using geometry for mates: In my old CAD system I have found it best to use a more static item (origin/plane/axis) for mates whenever possible/feasible to avoid making mates that fail as parts are changed. Especially I find it good practice to do this when placing sub-assemblies. In Onshape you have to first make a mate connector in the origin in each part and assembly to be able to do this, and this takes some time and you end up with tons of mate connectors in the origin of your assembly. And they add up as you add subassemblies mated the same way. Maybe a default mate connector in all parts/assemblies origin would be a good idea but I am not sure.
  • Member, csevp Posts: 694 PRO
    edited November 2019
    @PMS to address one of your points above: you can use this simple Featurescript that will add a MC at the origin for your part(s) in the Part Studio https://cad.onshape.com/documents/7a2aca223858e21747087f1c/v/d06b9de45deb6bba4211204a/e/36a983633c3f3c601fd50add. It's really handy, and you can use it to apply a MC to all the parts (or a subset) in the PS. Mating these MCs to an Assembly MC (at the origin) simplifies this issue. You still have many MCs to hide / show in the assembly, but at least they're all in the same place! You can select individual ones in the Instance List as usual.
    One area where Onshape has a superior (in my opinion) mating systems is that you Never use geometry for mates, you're always using Mate Connectors. You can more easily control Design Intent and downstream assembling by adding the Mate Connectors in the Part Studio. These MCs will also be available in the assembly, and they're easier to find because they appear in the Instance List in the dropdown for each Instance.
    Another tip that makes the "Show Mates" feature more useful: use the keyboard shortcut to Hide All the Mates first (J). Then, when you "show Mates", it will be the only one that shows.
    Lastly - I think I agree with the original post too: When I suppress an instance, I want the Mates to be suppressed too. Now that we have configurable assemblies, this is a common (and useful) workflow. Having all those hanging errors is a bummer when you are changing Configurations, because it will prevent Release of the Assembly.
    @romeograham
    you have to add the mates to the configuration suppression also.
    The point here is this should just be automatic upon suppression of one of the mated parts.
    Unfortunately, show mates does not work with sub assemblies, so you have to be a detective and find which part is the mate owner.
    All very tedious and unnecessary in this otherwise easy to use software. It is as if Onshape is still on mates version 1.0 and needs to finish what they have started
  • Member Posts: 30 ✭✭
    I have to add my thoughts on mates going red in an assembly when I suppress a part. It would be very helpful if they suppressed with the mated part. I understand this isn't an option in a configured assembly and that makes total sense but in a regular assembly this would increase productivity as I am suppressing them manually. Not a huge issue but would be nice if this could be made automatic.
    What do configurations have to do with it? If you suppress a part in a config, the mate will need to be suppressed as well anyway.
    mate's only support two mate connectors. so if one or both of the parts are suppressed. then the mate connector is un-used.
