Offset Fillet
bart_harris
Member Posts: 29 ✭
I have asked a similar question before and was told this feature is not available, but I'll ask anyway.
I have two parts: a lid and a base. I have filleted one edge by 10mm, top and bottom. What I would like to do is fillet the parts as one, with a 12.5mm radius that is off-centre on each part but looks like a semicircle when the are together. I have drawn a sketch to illustrate this.
https://cad.onshape.com/documents/e7fe3acecd91431ca74926e0/w/ce4cce5084114fabb00188a6/e/95adfd7e180549e2aa7c780a
Thank you.
Thank you.
Optionslougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001I would do this with a sketch fillet cutting from across the front. If the cut is not straight, you can sweep cut. The other option which @emmett_weeks added was to use a single fillet and then split the part into two parts.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
"Failed to load document for workspace. Resource does not exist, or you do not have permission to access it."
You don't need to trim the arcs to the horizontal line which is between the other two, but each arc should be constrained "tangent" to one of these two lines.
Now simply pick (first) the top region to extrude, and then the bottom one, specifying "New" for the second body so it becomes a separate part.
