Improvements to Onshape - April 17th, 2020
Roy_Mutalik
Roy_Mutalik Member, Onshape Employees Posts: 41 image
edited April 2020 in New in Onshape
Three more weeks have come and gone, so it's time for another release of Onshape!
Let's take a look at some of the improvements.
CAD IMPROVEMENTS
MAKE TRANSPARENT
You may now make parts temporarily transparent. This makes it much easier to work on internal components without having to fully hide exterior casings, etc.
https://onshape.wistia.com/medias/prxq9r8zf4
This feature is available in both Part Studios and Assemblies. You may also make surfaces, curves and meshes transparent the same way.
A new keyboard shortcut Shift + T has also been added to allow you to quickly add components to transparency.
Making parts transparent is a per-user operation so it will not disturb other users that may be working in the same assembly in the way that "hide" would.
SPLIT MULTI-BODY PART FILES INTO MULTIPLE DOCUMENTS ON IMPORT
You'll find improved options when importing multi-body part files, allowing you to split the bodies into individual Onshape documents.
https://onshape.wistia.com/medias/zn2u3s441z
This works for CAD neutral formats (STEP, IGES, Parasolid, etc.) as well as native (.sldprt, etc.).
CHANGE CONFIGURATION FROM SHEETS PANEL
You'll now find a right-click option to change the configuration of a part or assembly from the sheets panel in an Onshape Drawing.
Similar to the Replace feature, if Change configuration is invoked from the "Sort by sheet" tab, it will only change the configuration for that specific parent-child stack of references. If it is invoked from the "Sort by reference" tab, it will change the configuration for all references on the drawing (including views on other sheets).
RELEASE MANAGEMENT IMPROVEMENTS
INDICATION OF RELEASE-FROM-VERSION IN RELEASE CANDIDATE DIALOG
Last release included an improvement that allowed you to create a Release candidate from an existing version in a document. You'll now clearly see a version icon in the Release candidate dialog when an element in the Release candidate is selected from a version, rather than the workspace.
This is particularly useful if your Release candidate contains a mix of elements from both the workspace and a previous version, as shown above.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,059 PRO
    The transparent view is super handy. Thanks!
  • EricGauthier
    EricGauthier Member Posts: 73 ✭✭✭
    Make transparent? YES!!! :)
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    YES! Transparency without  changing the part properties.
    I'm guessing you copy/pasted the code for isolate and changed which parts got added to the ghost list eh? :wink:
    I'd prefer it was able to be sustained without the dialogue being open. But this works pretty well also, I'll get used to it. (just need to avoid hitting esc! I still hit that 3 or 4 times trying to unselect a part!) Stupid spacebar deselection... I still want to slap the S#!t out of who ever came up with that!
    Once you give us keybinding you know I'm changing spacebar to esc..  how would this affect a dialog box like this? Could you make this a little less volatile? or get rid of the keybind?
    Thanks!
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    Make transparent is a nice improvements.Good Work.
    @john_mcclary spacebar is soon much better than esc, once you drop those old CAD habits you'll learn to love it.  ;)  by habits i mean the complete package, I know, not your choice.
  • john_mcclary
    edited April 2020
    Problem is half the time Onshape uses esc correctly. So still need it bound on my mouse. Then the other half of the time i'm in autocad or solidworks.
    That and i have esc bound to a mouse button. So muscle memory is so deep it may as well be tatooed on my brain
  • emagdalenaC2i
    emagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
    Good job. I love the option to change the configuration from the sheets panel
    Un saludo,
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    @john_mcclary
    The running name for Make Transparent on the dev side was just Reverse Isolate :sweat_smile:
    The User Experience people eventually caught on and said we weren't allowed to name it that
  • john_mcclary
    LoL
    Kinda figured 👍
  • konstantin_shiriazdanov
    Transparency, finaly!
  • Ján_Zápražný
    Ján_Zápražný Member Posts: 6 PRO
    transparent finaly thanks
  • Theo_R
    Theo_R Member Posts: 82 PRO
    Great improvements!
    Would love to see a video for release updates that involve complex topics such as release management improvements.
    Thanks!
  • AlexPitt
    AlexPitt Member Posts: 22 ✭✭
    Thank you! All nice improvements. Especially the transparency/reverse-isolate! Just tried it; works brilliantly!  :)
  • frank_poggio
    frank_poggio Member Posts: 1 ✭✭
    Great job with the transparency! Just what we had asked for!
  • parviz_aghayarov072
    parviz_aghayarov072 Member Posts: 7 EDU
    transparent good addition)
  • left_side
    left_side Member Posts: 12 PRO
    Yes, transparent part options!  PERFECT!
  • 東_鈺
    東_鈺 Member Posts: 6 ✭
    edited April 2020
    There is no new function to input Chinese on the graph. Hope to add ...
  • BMcGaffey
    BMcGaffey Member Posts: 29 ✭✭
    Transparency! Awesome update
  • sid_nair
    sid_nair Member Posts: 5 ✭
    The transparency feature is great :smile:
    Well done guys.
    But another cool thing would be to have the option to change specific surface colours.
  • Josiah_Harthcock
    Josiah_Harthcock Member Posts: 57 PRO
    Yay, transparency! Thanks guys!
  • emagdalenaC2i
    Aquí podéis ver la novedades en Español
    https://youtu.be/VPdJtIYeero
    Un saludo,
  • Cache_River_Mill
    Cache_River_Mill Member Posts: 225 PRO
    Onshape is Amazing!
    Thank you team!
  • bill_rayner
    bill_rayner OS Professional Posts: 36 PRO
    Very nice! Particularly Invisibility and full-feature import.
    Thanks for not only continuing to respond to, or anticipate our needs, but also inventing elegant solutions as a FIRST iteration.
  • Roy_Mutalik
    Theo_R said:
    Great improvements!
    Thanks!
    Thanks for the feedback, Theo. It's a great point.
    Even though some of the Release management improvements are "smaller changes", the use cases can be more complex, and often are less apparent immediately. Our team will be sure to add videos for these in the future when possible, as well as provide a better context.
  • Theo_R
    Thanks @Roy_Mutalik!
  • turan_aydin
    turan_aydin Member Posts: 17 ✭✭
    Face color pleeese !!!
  • Jake_Rosenfeld
    @turan_aydin
    Your wish is our command
  • john_mcclary
    So all this time, we just needed @turan_aydin to ask politely... lol ;p
