exploded view as a configuration
Hi. Is it possible to make the exploded view as a configuration, that I can open in a tree and choose whether I want to see my assembly or the exploded view of it?
steven_bianco467 Member Posts: 1 ✭
No, It is not currently possible to control whether the assembly is displayed in its exploded state via the assembly configuration.Steven Bianco
Software Developer
Onshape5 -
john_mcclary Member, Developers Posts: 3,948 PRO
You can make a configuration that explodes. That was one of the old work arounds.
It will take a lot of time to setup, but it is doable. Just not at all compatible with the new explode fly out.
If you don't trust someone with edit permission, you should not give them edit permission. Set them to view only or comment. Then they can't break it.
Also Onshape has unlimited undo.. It is very difficult to permanently break anything. Even if you delete all of the tabs in the document.
Don't let fear keep you from learning your tools.6
Using the flyout tab on the right-hand side to create an exploded view. This is separate from configurations and I think you will like how it works.
Improvements to Onshape - March 9th, 2020 — Onshape
Software Developer
Onshape
And also when one opens the flyout and runs the exploded view, gets that yellow sign with "done" button ( when one gets the opportunity to change things in the exploded view.) It gives this confusing filling for people who are new in Onshape, like me
