Trim function doesn't seem to work.
paul_muller316
Member Posts: 9 EDU
I have drawn a square and a circle with the circle centered at the midpoint of one side of the square. I would like to trim away the parts of the circle overlapping with the square, but nothing happens when I choose the trim function and click on the parts of the circle. To see the trim function appear in the ribbon at the top, I click on "Sketch" and then click on the trim scissor icon.
NeilCooke
Moderator, Onshape Employees Posts: 5,964
Are you editing the sketch that has the geometry in it or did you create a new sketch?Senior Director, Technical Services, EMEA5 -
john_mcclary
Member, Developers Posts: 4,035 PRO
You will need to "edit" your existing sketch.
clicking sketch on the top creates a new sketch.
Also, trim will only trim entities that are intersected by other entity's in the Same sketch.
7
thanks, had the same problem
