Imported Files - Sketches and Offsets
geoff_josey
Member Posts: 65 ✭✭
Hi,
I wonder if someone could give me some guidance on the best strategy for this task.
I have dxf and igis files of a number of boat hull sections at various stations.
I have downloaded these into Onshape and want to create a sketch for each section. They are all overlaid in one view in the imported file.
The first problem i have is selecting the profile I want to work on. The second problem is offsetting the profile by 3.8mm which is the planking thickness.
I have looked at the guide which suggests that if I offset one part of the profile the rest of the profile will follow. It does not seem to work for me.
I am on a steep learning curve so any help is appreciated.
Thanks Geoff
Thanks Geoff
In your case, I would consider making a surface first, then thicken the surface. Try to keep from editing or adding onto the existing sketch if you don't need to.
Although I can't see the shape you are making. But usually a boat hull is pretty curvy. Which my mind goes straight to lofts and surfaces.
If I can come from a different direction. I have imported a test dxf file into Onshape. I then want to copy the imported polyline drawing to a sketch. I am able to select it for "copy" OK in the imported drawing but then cannot paste this into the sketch.
I am assuming that if i can get the profile into a sketch I may then be able to progress to the offset.
Start by creating a new sketch, then find the insert DXF option
What that does is take all of the compatible entities from the DXF and dumps it into a new sketch. You will need to constrain it yourself. After that you should be able to copy / paste individual lines or the whole sketch.
