Step problems
craig_stevens898
Member Posts: 2 ✭
Hi
I have a problem with Onshape ( I am new to it)
I get the following when i import a step file. Can anybody help me with this?
If it says Importing... Then Onshape is in the process of translating it into 3D model.
Once it is finished, you will see some part studios and assemblies appear (depending on your import type)
Importing can take a few minutes depending on the size of your model. Your's is 70mb so I would give it a couple minutes.
If there was a problem this notification well tell you if there was any import errors also.
