How do I thread a bolt?
mary_morrison111
Member Posts: 6 EDU
I'm new to Onshape. I'm a high school teacher who just started using this program. My students are designing toy trains. We need to do a bolt with specs of 1/4 - 20 UNC 1/2" OFFSET for the threads. I cannot find a tool to do this. Please help.
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
Many types of standard hardware are available to insert into an assembly. When in an assembly tab, just click Insert. Next, select the Standard Content tap.
5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,927
They can if they add this to their toolbar, or they can model it by hand.
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/v/845d049782179b9faee8b6e6/e/f8aea9e5c33e02eab0854a4f
Senior Director, Technical Services, EMEA6 -
EvanReese
Member, Mentor Posts: 2,693 PRO
That makes sense. If it's more about the exercise than the result (learning about threads, not just having them), then they'll have to:mary_morrison111 said:It's in the curriculum. I think it's there so the students are forced to understand what pitch is, and how to read the specifications. That's a very interesting point though and I will pass it along. Thank you and thank you for all your help today. Switching from teaching Autodesk Inventor in a school computer lab to teaching Onshape in distance learning overnight has been challenging. I truly appreciate the community of people, including you, who are supporting me.- make a cylinder with the correct diameter. (major dia for cutting threads or minor dia for adding them)
- make a helix on the cylinder with the correct pitch.
- sketch the thread profile
- sweep the profile.
6
Just something to pass on to your students. Gotta start them young
