Holes w/ Countersink on curved surfaces
Hi folks! I'm still struggling with easy hole creation on curved parts.
Consider the following steps to create a simple "pipe" shape:
1. On the Top plane create a new sketch
2. Sketch two concentric circles
3. Extrude to form a short pipe (20 mm depth)
Now, let's suppose I wish to create a hole through the wall of the pipe (e.g. along the X- or Y-axis), with a counterbore, in the dead centre (vertically / along the z-axis)
Can someone walk me through, step-by-step the following two scenarios:
A) create a hole in the centre of the pipe through one wall with the counterbore on the INSIDE
create a hole in the centre of the pipe through one wall with the counterbore on the OUTSIDE
I can achieve the above with offset planes, but I don't like that method because if I ever change the dimension of the original sketch circles, I have to move the offset plane manually.
I asked a similar question on this forum and it was suggested that I uncheck "start at sketch plane", but this hasn't been working for me to get a precise depth of counterbore.
Below is an example of what I'm looking for, in case I didn't do a good job describing what I'm trying to achieve.
Thanks in advance for the advice! Always learning....
NeilCooke Moderator, Onshape Employees Posts: 5,867
Please see the first comment (by me) here: https://forum.onshape.com/discussion/11239/improvements-to-onshape-march-1st-2019/p1
Also, how will you countersink the inside of a cylinder?(3D Print it is cheating).
Senior Director, Technical Services, EMEA5
Indeed! Further, the short video on Mate Connectors on that page sheds more insight into that function, which relates to my other question that you recently answered! BONUS!
What can I say? I am an amateur AND a cheater. But... I'm not sure I understand your question @NeilCooke !
