Bottom of Dialog Box Cutoff / Inaccessible
matthew_stacy
Member Posts: 489 PRO
in General
The dialog box to Insert-DXF-Into-Sketch does not fit on my display. As a result I can not access the unit select box at the bottom. Nor can I scroll down, unpin/relocate, resize, or any other trick that I can think of. Surely one of you clever folks has a solution to this. What am I missing?
It is quite maddening to import a sketch element at 1/25.4 scale TWICE before learning that there is an invisible-to-me unit selection box in the import dxf dialog. I have noticed similar behavior with other tools.
Please don't tell me to "buy a larger monitor". That utterly neutralizes one of the key advantages of cloud-native software like Onshape (offloading hardware to the vendor-side).
Is there any chance that a scrollbar could be added so that we don't have to zoom out, like how the mobile app's feature dialog works?
