Built-in documentation (markdown)
Currently users need to divide their documentation between comments and uploaded
files. Though the "File Upload" tab has its uses, it is a
cumbersome when the files need to be regularly updated. The "Comments"
feature, though super for collaboration, is better suited for small,
specific notes than providing general context, design intention, etc.
In software, programmers regularly include documentation files written in Markdown. This lightweight form of notetaking can add an invaluable layer of context to their code. Onshape could enable a similar functionality via a "Documentation" tab. Users could create the tab and write their notes directly using Markdown. There would need to be a way to toggle between "Edit" mode and "Visualize" mode.
Would this be difficult to implement from the programming side? Would other folks find this useful?
Design Engineer | Anerdgy AG
2
I think its worth making an improvement request that people can vote on.
You could create a new featurescript and use that as a notepad. Use commenting // Or /* */ To 'check off' things as they get done
Or go to the app store and add link tab.
That lets you directly link and edit a google doc
I got an x-frame-options error, was able to bypass that with an extension https://addons.mozilla.org/en-US/firefox/addon/ignore-x-frame-options-header/
but then it works, except there is the splash screen that is covering it up. @lougallo is that message coming from google or your app?
You can see the sheet has loaded, and I can interact with the controls above the error message.
