Configure Part Name Feature?
I actually worked on one for that too. It's here. To give credit where it's due, I started by copying one by @NeilCooke
(yet again) and modifying it only a tiny bit. Check his out here. I'd eventually like to find a way to toggle each field between a string or an equation, but for now, the prefix and suffix are strings and the segments are type "Any" meaning they can do calculations. It can also assign the part number if that's useful.2
(yet again) and modifying it only a tiny bit. Check his out here. I'd eventually like to find a way to toggle each field between a string or an equation, but for now, the prefix and suffix are strings and the segments are type "Any" meaning they can do calculations. It can also assign the part number if that's useful.2 -
It will not give me access to the first link. Perhaps it's private? @Evan_Reese
my bad I just made it public. give it a go now.cache_river_millworks said:It will not give me access to the first link. Perhaps it's private? @Evan_Reese
Excellent.
Is there a way to auto-populate some of the fields? Unless I'm mistaken, it seems like a lot of this just puts the data entry into one location. Which is great, but say I want the name to reflect the generated part number. Is there a way for the config to pull said part number, without me entering it manually?
@Design_Bro It depends on how large your scope is. If you are staying within the part studio and just want the name of the part to auto populate throughout the studio, then you can assign a variable at the start of the studio then use that variable to access the parts name.
If you want the name of the part to be accessible throughout that document, you can name the parts from variables from a variable studio.
If you need mass auto naming for part number generation, you would need to use an integrated app like Arena (PLM / PDM). Or you could have a custom app made that controls the names and meta-data per your specific needs. CADSharp specializes in custom apps and features so feel free to reach out to me if you need anything for your company.
Here is an example of an app we made a while back that controls the meta-data all tabs of related documents per project for the client. Something like this could be modified to set part numbers instead. How it works is it stores the project data somewhere, in this case in a single variable studio per that project. Then, it finds all of the assigned documents for that "Project". The app then finds each tab in all assigned documents and updates their meta-data (Client name, Project number, etc…)
RENDERCAD
________________________________________________________________________0 -
@EvanReese thanks for this! One issue … if you rename a part (e.g. Part1 → End1) and then apply the Part Name feature to the now-renamed part (End1), the name does not apply. I was able to reset the part to the default by going into the part's properties and clicking the Reset All button. But it seems like the feature should be able to overwrite the custom name.
1 -
@john_mccullough That is unfortunately a current limitation of all custom features due to the order the code regenerates in. The feature list generates first, naming the part, then the user-speficied part properties regenerate, overwriting the feature. Right now the Reset All button is the only way, but I'd love to have the ability to reset just one property in the future.
1 -
The Reset All saved me, thanks for sharing that - I was about to try that in desperation :)
