Chamfers different on identical edges
tony_459
Member Posts: 206 ✭✭✭
I have two parallel plates that I modeled by mirroring one across a plane. I applied a two-distance chamfer to identical edges on the two plates but the chamfers came out different.
The shallow end of one chamfer is the deep end of the other chamfer. It's as if distance 1 of one edge was distance 2 of the other edge. I can make the chamfers the same by doing them separately, but that adds a lot of busy work in the course of a model.
Just wondering if there's a reason the chamfer distances can't be consistent, at least when the parts are identical and literally mirror images of each other? Thanks
https://forum.onshape.com/discussion/9271/chamfer-feature-choose-direction-for-each-input#latest
