How to create the Axle for my F1 Toy Car?
I need some support on how to do the Axle of my F1 Toy Car, I was thinking of some ways on how to overcome it but still couldn't find the solution.
The Radius of the holes is 6mm as shown Above.
If anyone could give some support, I would appreciate it!!!
And send some drawings and models to make it easier 😁
Model URL: https://cad.onshape.com/documents/cd0dcf4fa3aa8939e925d7d9/w/dde0fc38f70bd48ba9cafd7a/e/1e89ff1e1a43fbe3fbdd5da5
When you click extrude, the top says
'New' 'add' 'remove' 'intersect'
You will need to select the area in the small cicle and double check that 'new' is selected. That will output the result to a new part.
Onshape loves to WRONGLY assume it knows what you want for a boolean condition. It is F@#$ing annoying and I hate how it switches modes to 'add' after your first input. Even if you pre-select a mode at the beginning of the command.
And could you also forward me that as well?
Is your plan to print it out 100% as shown in the assembly with the wheels in place? Or were you going to insert a metal rod into the hole as an axle and assembly afterwards?
The thing is that I want the Toy Car to move as well, when 3D printed
I'm not familiar enough with 3d printing to say it will roll good enough though.
So it doesn't have to be a pain for me to do it
https://www.youtube.com/watch?v=XnJBpCWf9Mc
