Onshape releases
Hi, just coming back in office after the covid lockdown to discover that Onshape no longer is useful on my PC. Worked fine before, then 4 months later there seem to be problems with WebGL. You'll probably respond that I should update hardware etc. Same thing happened when I started using onshape on Android 6 - suddenly one day the app needed to be upgraded and was incompatible with the OS.
Is it only me thinking that this is a serious problem when one plans for designing to find you need to buy new hardware because Onshape is a new release?
In the old times before SAAS we just re-installed the old program and you were up and running.
I would propose that Onshape let the user select between 1 continuing working with the same release or 2 using the current release.
It's a webgl problem, try updating browser or whatever your using. Just be aware there are a lot of people trying to make this work. Look up the kronos group and what they're trying to do. They're serious about this.
Please don't compare this to the old crappy desktop days, those days were horrible.
Sorry you're having issues.
The take home message, which Ill pass on to my students, is that you cannot be 100% sure that OS will work the day of your final thesis presentation, because some update (whatever its OS,WebGL, Chrome...) will knock you out.
The difference with Onshape is that if something somehow breaks on your machine's end, you can hop onto a different computer and start presenting there in half a minute, and there's never data loss.
In the case of Inventor, Solidworks, and other offline/file-based CAD packages, if your files corrupt, your computer fries itself, an automatic update breaks your CAD package, or any other issue happens, you're outta luck and will have to present another day (assuming you were running a good backup scheme for your project and can recover the files). Not to mention, ransomware and other computer viruses can completely knock out a whole company's engineering data, backups included, if they aren't careful with their data.
I've seen Solidworks and Inventor fail catastrophically during presentations, but have not seen Onshape do so. Yes, it can fail, but it does so much less frequently and in a much more recoverable way.
Plus, if you're worried about an operating system upgrade breaking your computer, you can use Ubuntu LTS with Onshape for a consistent, reliable experience for years at a time with full control over updates/upgrades. On the other hand, with Inventor, Solidworks, and others, you are subjected to the whims of automatic Windows updates.
