Sketch linear pattern: not possible to set #instances to a variable?
timo_schmid
Member Posts: 36 EDU
in General
Hi everyone,
I'm trying to pattern a sketch entity multiple times, and have the number of times dependent of a variable.
However, Onshape does not accept a variable as an input value there. (In contrast, for the distance between patterns, it is no problem to select a variable)
Does anyone know why that is, or if it's still somehow possible to have the #instances as a variable?
Thank for your help,
Timo
