How do I see the names of the parts in an assembly?
martijn_grunwald
Member Posts: 5 ✭
I create parts and give them names. After importing them in an assembly, I don't see the names of the parts
You can also change the name here as well.
It looks like the BOM is correctly showing the quantities of the parts, but it appears empty because the parts don't have descriptions or Part numbers. If the parts have names, they'll show up when you add the Name column.
