hotkey and quick menu for Create Selection
EvanReeseEvanReese Member, Mentor Posts: 2,857 PRO
edited September 2020 in Product Feedback
I'd like to have a way to bring up a Create Selection menu like the one you get by pressing S. I also want to see a set of icons for each selection type instead of the Enum dropdown which takes a lot of clicks. It would be great if there were a different hotkey for a face-selection and an edge-selection. This workflow would be one keystroke and two clicks (select entity, and select criteria icon).
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @Evan_Reese We will leave this to when you have the option to build your own quick keys.  Not taking requests on any other hard coded shortcuts at the moment.
  • ryan_mcgoldrick47ryan_mcgoldrick47 Member Posts: 93 ✭✭✭
    This would be awesome! would improve the current tool workflow. Can we build our own quick keys currently?
  • andreas_ranch146andreas_ranch146 Member Posts: 4 PRO
    I can't believe this has not been implemented yet. Creating selection, and switching view modes (shaded/unshaded, hidden line on /of) requires WAY to many clicks through sub menus.
