how to draw part of assembly?
malet_jl
Member Posts: 15 ✭
hello,
I have an assembly, that is configured using configuration variables, this assembly has sub assemblies, which are in turn configured with configuration variables, and parts that are in turn configured....
I now want to create a drawing for production, but I need to draw using the assembly configuration.... I didn't found a way to import a part configured from the assembly, I can import parts but the dimensions aren't good...
I can create exploded views, which is great, and in a way answer my needs, but on the exploded view, I can't hide some parts.... which makes impossible to only show what is required...
how can I do that?
thanks and regards
how can I do that?
thanks and regards
NeilCooke
Moderator, Onshape Employees Posts: 5,997
Display States, in the assembly, will hide other parts - or you could just find which configuration of the part is used in the assembly and create a drawing of that.Senior Director, Technical Services, EMEA5
