New User Dimensioning Problem
brad_strassburger146brad_strassburger146 Member Posts: 5
edited October 2020 in Community Support
I am new to onshape (and cad in general) so I apologize if this is a really stupid question. I am trying to add dimension to a sketch that will cut out a section of my shape, but whenever I put the dimension in, it turns red and becomes unusable. I assume this is a warning of some type but I do not know what it means or how to fix it. Can anyone please help.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    It's because you have constraints to a vertex, the origin and a dimension which all conflict - choose one to delete
    Your sketch becomes over-constrained when you have it fully defined and attempt to add another driving dimension.  See the Learning Center and help on these topics.
    www.accuratepattern.com
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,962 PRO
    Can you link your document so we can take a look?
    It is likely a constraint that you aren't aware of
  • brad_strassburger146brad_strassburger146 Member Posts: 5
    Thank you so much. Such a simple solution. Sorry for the simple problem.
    No apologies, That's what this forum is for. Sketch constraints are a confusing concept for most people when starting out.
    But like Bruce said, the learning center is full of useful lessons and quizzes.
    It is highly recommended you go through some of the self paced courses. Until then, we will always be here to help.
