New User Dimensioning Problem
I am new to onshape (and cad in general) so I apologize if this is a really stupid question. I am trying to add dimension to a sketch that will cut out a section of my shape, but whenever I put the dimension in, it turns red and becomes unusable. I assume this is a warning of some type but I do not know what it means or how to fix it. Can anyone please help.
NeilCooke Moderator, Onshape Employees Posts: 5,896
It's because you have constraints to a vertex, the origin and a dimension which all conflict - choose one to delete
Senior Director, Technical Services, EMEA1
It is likely a constraint that you aren't aware of
https://cad.onshape.com/documents/e87695c881453a0c2d24dc83/w/e33f9b571a6d08738cc6bbf1/e/f6e4296c3d5b71c607d0e7f5
But like Bruce said, the learning center is full of useful lessons and quizzes.
It is highly recommended you go through some of the self paced courses. Until then, we will always be here to help.
