Which mate to choose?
benedikt_hartwegbenedikt_hartweg Member Posts: 3 EDU
edited October 2020 in Using Onshape
Dear Onshapers,
I need your help on this matter. I cant seem to find the proper mate for this application.
Please see the pictures attached below. I want to mate the wheels of the gantry cart to the v-shaped extrusion (based on the openbuilds system). I already tried the "normal" mates, like the slider edge using some edges and also the tangent mate, but they just wont do the job.
There´s no need for the wheels to actually turn.. I just want to be able to move the cart along the extrusion.
Many thanks and take care,
Ben
    bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    Slider mate will be the one.  If you share your document, we can help more specifically.
    I suspect you are having trouble with offset of mates.
    See here for instructions on sharing - https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
    www.accuratepattern.com
    Hi Bruce, thanks for your help. I added the link :smiley:
    The document is not public - please see the instructions for making public and copying the URL.
    Also - it would help to have your 'broken' attempt at Mate and create a version so we may review even if you change document.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    Defiantly slider.
    Either you can do it with an offset in place.
    Or you can create a mate connector in the sliding plate partstudio that has the offset, then add slider to that.
    michael3424michael3424 Member Posts: 679 ✭✭✭✭
    All slider constraints should be done defiantly  ;)
    Damn spell check.. lol clicked the wrong correction
