I'm having difficulties with the sweep feature, can anyone help?
tyler_vandewal
Member Posts: 7 ✭
I'm going through the Part Design tutorial creating a paperclip, and the sweep feature doesn't seem to be working. The figure I'm using to sweep is a 5 mm circle, and the path is a simple paperclip design that isn't an actual part yet, just some lines. The sweep path is on the top plane, while the profile sketch is on the right plane. At first it goes well.
However, after this, it just seems to break.
I tried selecting the whole figure anyways to try and have it fix itself, and it worked to an extent, but the size is all wrong and it's just off for some reason.
Can anyone help? I'm not sure what's going on here. I followed the directions, all the dimensions are correct and they're all on the correct planes. All arcs are tangent to all lines. I don't have a clue.
Principal Technical Services Engineer, Onshape
jjohnson@ptc.com
Yeah, the tutorial said to apply the coincident constraint to the center of the circle and the endpoint of the path sketch
@alnis_smidchens is correct about the gap between your profile and your path:
If you make sure the profile sketch is touching the start of the path, everything will behave more nicely. That is what the info message at the top of the page "For best results ensure that the path intersects each profile or its plane" is trying to tell you, as well.
If the sketch were fully constrained, it would be black instead of blue. Maybe the start or end point of the path is supposed to be coincident with the origin? I am not familiar with the lesson, but I could look if you posted a link.
https://learn.onshape.com/learn/course/fundamentals-part-design-using-part-studios
The paperclip part is the second or third part of the lesson, though.
