How can I change the dimension of a new part that is extruded from an existing part
david_skinner082
Member Posts: 3 ✭✭
Is is it possible to change the dimension of a new part that is extruded from an existing part to give the new part a clearance fit? The 2 parts modelled from each other have the exact same measurements so would not easily fit together
Many thanks in advance.
Optionsmahir Member, Developers Posts: 1,291 ✭✭✭✭✭There are countless ways to accomplish what you want. Here's one method using 1 sketch, 2 extrudes, and 1 move face. There's no one right way. Based on how you've modeled your parts, I feel like you would get the most benefit from completing some beginner tutorials. Here's a link to the CAD basics learning pathway.6
https://cad.onshape.com/documents/5f9ff18b8b74f9a8353acb74/w/a0b360837ea26b90f050c129/e/c579846ae9edb7aec3a5787b
