How can I change the dimension of a new part that is extruded from an existing part
david_skinner082david_skinner082 Member Posts: 3 ✭✭
Is is it possible to change the dimension of a new part that is extruded from an existing part to give the new part a clearance fit? The 2 parts modelled from each other have the exact same measurements so would not easily fit together
Many thanks in advance.
    mahirmahir Member, Developers Posts: 1,291 ✭✭✭✭✭
    No problem. Glad to help.
