Im a jr in High-school doing a public project, but i don't know how to make smooth complex surfaces.
joshua_davis740
Member Posts: 6 EDU
in General
Is there any way i can add on to these simple surfaces to allow more curvature without using fillet or any of the simple tools provided? I'm new to onshape. 0
https://learn.onshape.com/learn/learning-path/advanced-part-and-surfacing-design
Admittedly, I do still need to finish the pathway, but the parts I have done so far have been very helpful.
Also - this thread has some good information about curvature that applies both to surfacing in general as well as non-circular fillets, splines, etc.
https://forum.onshape.com/discussion/14179/curvature-explained-for-normal-people-video-with-animations
First off — thumbs up on what @alnis_smidchens says
https://forum.onshape.com/discussion/comment/64799#Comment_64799
By the way, for just starting in Onshape, your model looks pretty cool. That’s an old man’s way of saying nice work.
If you read the entire post that I linked to, there was one place where I made the following statement —
Then one at a time, delete one of the tangent constraints and replace it with a curvature constraint.
Disregard this. There’s no need to delete the tangent constraints
Leave the tangent constraints in place. And then apply the curvature constraints when called for, in the post
