How to Constrain and Entire Imported Sketch Element (dwg)
matthew_stacy
Member Posts: 487 PRO
@NeilCooke created a nifty video demonstrating how to insert a dxf/dwg file into a sketch (https://www.onshape.com/en/resource-center/tech-tips/tech-tip-turning-your-2d-drawings-into-3d ). All good. But is there a way to constrain the entire sketch once it has been transformed to the proper location? I'm seeing a lot of blue there!
I was hoping to just do a Box Select and Fix. But that is insufficient to constrain an entire sketch.
Suggestions?
I'd also really love for Onshape to roll out some kind of sketch block functionality which could be used to create a library of recurring sketch items to be placed into sketches, preferably also grouped together somehow, so you can't accidentally modify the group. I can think of some workarounds for this, perhaps with Featurescript, but it's not the same.
Website: ovyl.io
- https://cad.onshape.com/documents/c19ef31ba3cb4d60d00869a0/w/71d7c5869e2980ee41997c33/e/29643d9eb27039a445860af3
After inserting the DXF 22 mouse clicks are required to fully constrain the sketch:Website: ovyl.io
SEE POST BELOW
Select top plane
Select use tool
Select top face of part
If you don’t like having the unconstrained imported DWG sketch in the same document, and as the first feature
Then —
Extrude unconstrained DWG
Export part
Import part into new document
Select top plane
Employ USE tool
Website: ovyl.io
@Evan_Reese
Here’s the sequence
unfortunately when I make longer GIFs, I get dropped frames. So ...
Website: ovyl.io
Big time saver on some projects
sketch entity:
relationship assistant constraints selected
relationship dimensions selected
resulting sketch
Twitter: @BryanLAGdesign
